valueError: Supplied state dict for layers does not contain `bitsandbytes__*` and possibly other `quantized_stats`(when load saved quantized model)
We are trying to deploy a quantized Llama 3.1 70B model(from Huggingface, using bitsandbytes), quantizing part works fine as we check the model memory which is correct and also test getting predictions for the model, which is also correct, the problem is: after saving the quantized model and then loading it we get
valueError: Supplied state dict for layers.0.mlp.down_proj.weight does not contain bitsandbytes__* and possibly other quantized_stats components
What we do is:
  • Save the quantized model using the usual save_pretrained(save_dir)
  • Try to load the model using AutoModel.from_pretrained, passing the save_dir and the same quantization_config used when creating the model.
Here is the code:
model_id = "meta-llama/Meta-Llama-3.1-70B-Instruct"
cache_dir = "/home/ec2-user/SageMaker/huggingface_cache"
quantization_config = BitsAndBytesConfig(
    load_in_4bit=True,
    bnb_4bit_quant_type="nf4",
    bnb_4bit_compute_dtype=torch.bfloat16,
    bnb_4bit_use_double_quant=True,
model_4bit = AutoModelForCausalLM.from_pretrained(
    model_id,
    device_map="auto",
    torch_dtype=torch.bfloat16,
    quantization_config=quantization_config,
    low_cpu_mem_usage=True,
    offload_folder="offload",
    offload_state_dict=True,
    cache_dir=cache_dir
tokenizer = AutoTokenizer.from_pretrained(model_id,cache_dir=cache_dir)
pt_save_directory = "test_directory"
tokenizer.save_pretrained(pt_save_directory,)
model_4bit.save_pretrained(pt_save_directory)
## test load it
loaded_model = AutoModel.from_pretrained(pt_save_directory,
typo.
to
tokenizer.save_pretrained(pt_save_directory)
This is a bug in the _load_pretrained_model() function of
transformers/modeling_utils.py when loading sharded weight files. The
state_dict is applied to the empty model per shard. This is problematic as the
quantized weight and its meta data(*.quant_state.bitsandbytes__nf4) may be
stored in the different shards. The quick-and-dirty fix is to merge tensors
from all shards into one state_dict. Similar issues have been reported on stackoverflow
and the unsloth github issue 638
Is this issue fixed ?
I am getting the same error
in
import torch
from transformers import (
pipeline,
BitsAndBytesConfig,
1) Build your 4-bit config.
bnb_config = BitsAndBytesConfig(
load_in_4bit=True,
llm_int8_enable_fp32_cpu_offload=True, # keeps some weights in FP32 on CPU
bnb_4bit_quant_type=“nf4”, # or “fp4”, “fp4-dq”, etc.
bnb_4bit_compute_dtype=torch.float16, # compute in fp16 on GPU
2) Create the pipeline, passing quantization_config:
pipe = pipeline(
“image-text-to-text”,
model=“unsloth/gemma-3-27b-it-unsloth-bnb-4bit”,
cache_dir=“/mnt/models/gemma3”,
trust_remote_code=True,
device_map=“auto”,
quantization_config=bnb_config, # ← here’s the key
messages = [
“role”: “user”,
“content”: [
{“type”: “image”, “url”: “https://…/candy.JPG”},
{“type”: “text”, “text”: “What animal is on the candy?”}
print(pipe(text=messages))
Maybe not yet.
